跳转到主内容
修复你的物品
维修的权力
配件 & 工具
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure.
174 个问题 查看全部
The washer fills then jumps to spin cycle
the washer fills then the cycle light immediately switches to spin indicator cycle then after 2 minutes in that cycle stops and the oL light comes on.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
I just changed the suspension rods and now my machine is doing this! But no code comes up.
完成的
添加一条评论
Manta 螺丝刀工具包
112 bits for every fix.
Upgrade Your Toolbox
Manta 螺丝刀工具包
1个回答
已选择的解决方案
I would replace the timer.
Second, OL stands for “Overload”, so in other words, the washer thinks the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to “float”.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Kevin Campbell 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 179
