跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3855 个问题 查看全部
apple logo flash then black, backlit screen
Ok so, itried fixing a water damaged iphone 5s today and did the whole alcohol thing. so i put the motherboard in and tried turning it on... nothing. so i plug it in then i get an apple logo for about half a second then it switches to a black backlit screen and stays there. maybe i didnt remove all the corosion and need to clean it more? by the way i did plug it and itunes recognizes it and i restore it... i get an error code 3194. right now i am stuck and have no clue what to do because i spent a lot of money for the parts. I know the parts are 100% working because i tested them on a different motherboard.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
Does the iPhone serial number and model number appear in itunes when it's in recovery mode?
If not then there is a hardware issue on the phone. Otherwise error code 3194, which can be fixed by updating your iTunes. If that doesn't work then try another iPhone 5 USB cable and other usb port.
这个答案有帮助吗?
按维修分数 1
评论:
i did everything you said and the serial number is showing but i still get an error code 3194
添加一条评论
when was showing apple logo and turning of
was it into a loop?
this sound like a issue with the battery.
if u take out the battery and plug it in does it do the same?
is so replace battery should be the issue
这个答案有帮助吗?
按维修分数 0
评论:
i tried it with a different battery and still the same. and it kind of is a boot loop but it stays on a black screen for like 10-15 mins
have you tried to enter recovery mode and restoring it?
when i try to put it to recovery mode the apple logo lights up for 5 seconds then the screen goes black. it is still detected in itunes but i try and recover it and it gives me error code 3194... again
显示更多的2条评论
添加一条评论
hello if the display you've tried it another motherboard and is it then tries again to wipe the motherboard, often I had to wash several times motherboards to remove all the residue of the liquid, if you have not already done so, cuts cover plates around the cpu and gpu following the holes on the sides, always very carefully.
from those holes often enters the liquid and if you remove the protection you can not solve.
I use contact sprays or washes ultrasuoni.in ultimately double check with a microscope or a very powerful lens the contacts and if you do not remove oxidation also is using a delicate brush brush, it is possible that some welding is to be redone.
good luck
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
christian lopez 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 7
总计 753
