跳转到主内容
Repair guides and support information for RCA-brand tablets.
1271 个问题 查看全部
won't let me swipe up to unlock
My tablet is broke and i can not fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
13条评论
It won't let me go in to get on my password
完成的
All of my home screen buttons won't work to let me get back to my home screen
完成的
My tablet slim is unblock I can use my tablet
完成的
My tablet won't let me swipe to unlock it
完成的
It won't let me swipe so I can get in
完成的
显示更多的8条评论
添加一条评论
4个答案
最有帮助的答案
Found this information on the RCA 10 Viking Pro Repair page at ifixit.com in the User Manual.pdf on Page 30:
-Tablet is frozen or a serious error appears-
If the tablet is frozen or suspended, you may need to close the app program or reset the tablet.
If the tablet is frozen or slow to respond, press and hold the power button for 8 seconds to reset the tablet. (This is what fixed the problem on my RCA Voyager Pro, and I had to sit through about a minute or two of waiting for it to start up, again, but the Slide Up unlock feature finally started to work after doing so)
If that doesn't work, press the RESET button at the back of the tablet; then press and hold the Power button for 4-5 seconds to turn on the unit.
这个答案有帮助吗?
得分 3
5条评论:
I did all the above and it won't let me slide up to unlock it.
完成的
Me too, and I don't see a reset button on the back. It let's me enter my code during the reboot, but when it goes to its background screen it still won't let me slide to unlock it back to my unlock code screen. And it's only two days old. :(
完成的
Mine is doing the same
完成的
Turn it straight up then try
完成的
I learnt a lesson , avoid RCA , thanks for all the ideas but all attempts have failed
完成的
添加一条评论
Bingo! I justg figured it out. You have to have the tablet in portrait mode! Swiping won't work if the tablet is in the horizontal or landscape orientation. Hopefully this is a bug they're going to fix! It's annoying....
这个答案有帮助吗?
得分 1
3条评论:
Ok so when will it be fixed tks
完成的
How long will it take to fix?????
完成的
I am waiting for a answer to my question?????
完成的
添加一条评论
Basically, you want to reset your tablet so, with your tablet off, press and hold the volume up button and the power button at the same time until the RCA logo comes onto your screen then let go, next, use the volume down button to select the wipe date/factory reset, then let it finish, lastly, select “reboot system now”
这个答案有帮助吗?
得分 0
2条评论:
I have a green box that is popping up on my tablet around where I swipe to open it and I can’t get into the Lenovo tablet. HELP
完成的
I've done this, it's asking for the previous owners email. Won't reset new email account.
完成的
添加一条评论
My RCA tablet will not let me swipe up and when i push the power button it's on screenshot and i can't power it off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jalyric moultrie 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 98
总计 13,677
