跳转到主内容
加入维修社区 - 创建账户
Toshiba Satellite C850 发布于 2012 年,是一款 15.6 英寸的笔记本电脑,提供 AMD 或 Intel 处理器可选。它配有 USB 3.0 接口,并可配置最高 1TB 的 HDD 硬盘和独立显卡。
How do I clean out my fan and exhaust grill?
so my toshiba satellite keeps getting hot (Really hot) from a few hours of use
i havent cleaned out my laptop in a few years or so, i found this tutorial wherein i can clean the fan and the heating grill with a brush, but my question is. do i have to reapply thermal paste if i take apart the cooling system?
and if not is there a safer way to do it other than taking apart my entire PC just to remove dust bunnies from the fan and or the exhaust grill?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Remove cover locate fan there should be a couple of screws securing fan remove fan use a can of blowout to clean heat sink and fan.
这个答案有帮助吗?
得分 1
1条评论:
so i dont need to remove the copper heatsink?
由完成的 分享
添加一条评论
最有帮助的答案
@maxushero you should not have to routinely change the thermal paste, but if your computer is/has been overheating and you are going to resolve that, I suggest that you replace the thermal paste as well. Get it done ones and get it done right. No shortcuts for the disassembly. Use the guides.
这个答案有帮助吗?
得分 4
3条评论:
it doesnt overheat at all. im just concerned because it gets Really hot (to the point where i can feel it from the keyboard) i just need to know that if i want to remove dust from the fan and the exhaust grill, do i have to re apply thermal paste? because if i remove the copper heatsink what would happen to the thermal paste that's already in there?
由完成的 分享
Part of the thermal paste will stick to the heatsink and the processor. So if you wipe it off you will have to replace it. If you leave it alone, you may get away with not changing it. I just feel that if you go through all the effort, then it might be a good thing to replace the paste as well.
由完成的 分享
Thanks! this helped me alot. all of you :) im forever in your gratitude
由完成的 分享
添加一条评论
添加你的答案
maxushero 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 970
