跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1232 个问题 查看全部
New lcd installed from ifixit can't swipe to open
Prior to lcd install, screen was black , new lcd turns on and lights up beautifully, can't swipe to unlock though. Have tried hard reset many times to no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
Check your connections on the actual led and on the logic board.
这个答案有帮助吗?
得分 0
1条评论:
I have disassembled three times and updated to the new iOS. The screen will not unlock. Siri can open phone but have no touch.
完成的
添加一条评论
i had problem with the touch connection on the iphone 5c. It had to be just right fit to make the touch work.
If you get the click sound, then you are got good connection, if not, redo the connection.
这个答案有帮助吗?
得分 0
添加一条评论
try the old lcd, do you have the same problem with the old lcd?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brian snyder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
