跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
90 个问题 查看全部
PSP Go won't stay on
So, I tried turning on my PSPGo but it wouldn't turn on even if I tried charging it. I thought it was the battery, so I ordered a replacement and it still wouldn't turn on. Then I looked it up and someone gave me the idea of hitting the back and boom, just like that everything was functional again. But then after like 5 or 6 minutes it would turn off and go back to the way it was. I can still repeat the process of hitting the back, but like I said, it turns off after a few minutes.
Any idea on what it could be? Is it something I could fix myself?
Thank you in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
It is probably a case of a bad connection somewhere inside the gadget. If you are technical or you have guts to explore unknown territories then I suggest go on Youtube , find teardown procedure, check every wire and every connector in and out and if this will not be helpful enough, try to "reheat" carefully crucial elements on the board (always avoid capacitors, transistors or anything containing plastic melting material).
Last part is really tricky and needs a lot of patience. You can find a lot of articles on the internet about reheating logic boards.
IMPORTANT: STOP USING PREVIOUS ADVICE WITH BUMPING DEVICE AT THE BACK.... you are causing even further damage - in case that you have just a disconnect wire situation this loose wire can accidently touch something which shouldn't be touched and permanently damage your device ( loose metal pieces or elements are the same ). Usually if little bump is not good enough we need a bit more force, than kick, later little throw and in the end - throw in the garbage bin.. :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mluciano11 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 351
