跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
My iPhone wont turn on after piece broke off!
I was trying to fix my iPhone (Broken screen) but when i lifted up the shield that protects the connectors for the screen this came off and im not sure how. Now my phone will not turn on anymore, I can charge it and I hear noises along with receiving messages and it vibrating. Im not sure what I broke but nothing will turn it on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
That's the screw socket for the center screw on an iPhone 6 flex cable cover.
As far as the power up goes, the phone is turning on. You could have a bad screen, a poorly connected screen, blown backlight filter/diode, blown component in the image line. You could have knocked off any of the tiny capacitors/filers/diodes from around the area of the connections. Long story short, it could be many things. I would start off double checking my connections and a known good screen. The connections should have a solid click feeling when you seat them right. You can also shine a light at the screen to see if the image is there, but not lit. This would tell you if there is an issue with the backlight line.
Hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
Hey :)
did you try put the "new" screen on to see if you can get it on ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
benvuolo123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 87
