跳转到主内容
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 个问题 查看全部
Film counter doesn't work
Why doesn't film counter work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
14个答案
最有帮助的答案
It stays at “S” and the piece of the plastic that presses the button is still there
这个答案有帮助吗?
得分 6
3条评论:
It’s because you need new film
完成的
Added new film, what else could it be?
完成的
I'm having the same problem I changed the batteries and the film looked at the metal piece everything is fine but still showing S and not working?
完成的
添加一条评论
The plastic is still attached to the back but still isint counting, does it mean i broke it? How do i fix it?
这个答案有帮助吗?
得分 5
1条评论:
yah,same how can i fix it
完成的
添加一条评论
open the compartment for the film...
you will see that in the middle of the right there is a small silver piece of metal....
if you press it in, the numbers will count, if you do NOT, it will return to "S"
So now look at the door is the piece of plastic that presses that button still there, did it chip off?
这个答案有帮助吗?
得分 3
9条评论:
I’ve tried this and all my stuff is intact, but it still doesn’t work, what can I do to fix it?
完成的
I was with the same problem and now it’s solved, thank you so much
完成的
everything is intact but it still doesn't work please help me!
完成的
U NEEd A NEW FILM
完成的
anyone knows how to fix it?
完成的
显示更多的4条评论
添加一条评论
My Polaroid has 3 film left and it wasn’t taking pictures so I took out the film then it turn to s
这个答案有帮助吗?
得分 2
3条评论:
ofcourse because its finished add a new pack of film to fix
完成的
My camera has blinking lights and when the film is in it says ‘s’ on the back will someone please help please
完成的
I have the same problem. Please help
完成的
添加一条评论
My counter wet from 6 to “s”. Help me please.
这个答案有帮助吗?
得分 0
3条评论:
How can i fix this?
完成的
I noticed that when you open the back of the camera (to where the film is) the counter resets back to "S" so maybe you opened the back of the camera before you finished all of the film?
完成的
So of I opened the back of the camera when it had 6 left, it doesn’t work more? Because mine went from 6 to S too???
完成的
添加一条评论
That does’nt mean that your camera is broke it just simply means you need to replace the film.
这个答案有帮助吗?
得分 0
添加一条评论
No matter what I do, the counter stays at S. I even poked the plastic piece and the counter didn’t move. Maybe it’s jammed? But why?
这个答案有帮助吗?
得分 0
1条评论:
if the counter is already at S the counter won't move when you poke the opening (silver button inside) right of the film. can you try to jam that button, maybe with a matchstick or something else and see if it starts moving when you take photos.
完成的
添加一条评论
This is just a guess since i have the same problem with my brand new camera, im guessing that if youre camera is new its still not going to work completly espescially if its the very first film pack you put in it
这个答案有帮助吗?
得分 0
添加一条评论
I know this is a little late to help anybody but I had the exact same issue. I ended up putting in brand new batteries and it worked for me. The new blank black sheet came through and my new film was good to go.
这个答案有帮助吗?
得分 0
添加一条评论
Hey can anyone help me . I just got my instax minni 9 and the black plastic is suppose to come out first but mine had gotten stuck and my lights started to flash . I added new batteries and i took out the black plastic thing from the film and still wont work? What do i do can it be fixed ?
这个答案有帮助吗?
得分 0
4条评论:
LOL i have now the same problem, do you fix it?
完成的
Change a new pair of battery
完成的
Mine where you put your eye that light comes on but it will not take a pictures or anything and i replaced the batteries put a new cart in and its between 1 and 2 on the counter ?? idk what to do
完成的
same thing is happening to me!
完成的
添加一条评论
I have an issue where the counter goes down too fast to tge point where it could be on 0 and I still have film in my camera. (As I can still take a few pictures).
I'm guessing the counter is going down 2 at a time.
这个答案有帮助吗?
得分 0
添加一条评论
Hi all having the same problem with my mini 8, only i bought mine second hand, was showing working etc, I get my hands on it and can't get it working. I tried it when I first had it, and a blank film came out.. So I Bought a new one, put that in and I'm getting the same, red light stays on, with S in the counter. I checked all above and everything is in tact.. Now what lol
这个答案有帮助吗?
得分 0
添加一条评论
S means it’s on selfie mode
这个答案有帮助吗?
得分 0
2条评论:
"S" stands for start
完成的
Well that was the case with mine and when I switched the modes it went back to counting down the numbers. The little house mode turned the numbers to the S and when I rotated the mode to the little sun it went to the numbers.
I hadn’t realized it was even an option to rotate those modes and the pictures were coming out completely white. Anyway tested it by taking a picture facing selfie and it worked. Messed with it til I realized I could rotate the modes.
完成的
添加一条评论
@Anahi Gutierrez "S means it’s on selfie mode" = NO
"S" stands for START... the first time you take a photo it will release the plastic cover... that is why there is an "S" before the 0 (ZERO)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Albert 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 51
过去 30 天: 276
总计 131,224
