How to replace a camera flash bulb that's shattered inside housing?
Flash Bulb Repair:
Sony α6000 Mirrorless camera w/ 16-50mm lens ILCE-6000L
Product: Sony ILCE-6000
My flash bulb has shattered inside the flash housing. I can see shattered glass rolling around inside the translucent assembly. I spoke with Sony who won't fix the camera for under $300 because it's out of warranty but I found the replacement part online for about $50.
I'm hoping someone might have guidance on how to replace a flash unit on a SONY A6000 or similar mirrorless interchangeable lens camera. The flash is spring loaded and from frequent use I believe the jarring nature of the spring mechanism to be at fault for the internals shattering. Poor design has been a frequent issue with this camera as I have already had it in for repairs in the brief time that I've owned it.
Flash Unit:
https://www.encompassparts.com/item/9597...
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
