跳转到主内容
Released June 2014, identified by model 635.
54 个问题 查看全部
Touch function repair after falling to water (3 months later)
Hello!
I have a Nokia Lumia 630 and three months ago it got wet. After three days it functions, but the touch screen doesn't. How I can repair it?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Oh it could be a couple of things
First the screen itself.
Second the touch circuit inside you phone.
Either way once the phone dries it starts corroding on the inside.
The least that you could do is tear it down and clean the board and connectors with 90%+ IPA.
Then reassemble and assess.
Or send it to a pro shop for pro cleaning if the board is too corroded.
However if it was me, I wouldn't spend time and money on a liquid damaged phone unless the damage is very limited since otherwise they tend to fail over time, one function after the other as corrosion eats away at them or the corroded and weakened joints -even after cleaning corrosion- start failing.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sebastian Zunino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 74
