跳转到主内容
修复你的物品
维修的权力
商店
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
636 个问题 查看全部
Broken LCD and screen, digitizer ok
I cracked the screen on my phone recently went about trying to fix it myself. I am kind of short on cash so I tried replacing the screen only and not the lcd. When I tried separating the screen from the lcd, the dark glass part remained on the broken screen and the light grey bit remained behind. I was just wondering if there was a lesse expensive way to repair the phone without having to replace the entire front assembly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
Its galaxy S5 !!! You need a lot of work to separate the upper glass from LCD and a lot more work you separate LCD from the frame !!! Just buy a full glass-LCD-frame replacement
这个答案有帮助吗?
得分 0
评论:
You broke your LCD anyway !!
完成的
添加一条评论
Here is the video showing how to replace only the s5 glass: https://www.youtube.com/watch?v=PfJ2ap2p... . It seems a little bit complex and ask for the professional skills and repair equipment. It may be difficult for a DIY repair work, and you'd better replace the whole screen including the lcd screen and touchscreen and the front glass.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ryan bob 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 4
总计 304
