跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
793 个问题 查看全部
Does iPhone 6s Plus uses the same speaker module as iPhone 6s?
Hey all! I already replaced two iPhone 6s phones and both of them had terrible crackling/distorted sound. Now I'm wondering to switch to iPhone 6s Plus. So does the 6s Plus uses the same speakers founded in 6s or it's diffrent? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
I tried this with a iPhone 6 and iPhone 6 plus phone before. It didn't work because the plastic screw holes on the earpieces were either too high or too low to screw in properly and be mounted firmly for full contact with the 4 gold connections on it.
TL:DR - It will not work as well for iPhone 6s and 6s plus as they are different.
Thank you so much. So there is a chance that problem will not occure cause they have diffrent speaker systems?
I'm just windering of purchacing iPhone 6s Plus and return my iPhone 6s.
添加一条评论
Apple Watch 套装
Screen and battery repairs just got easier.
现在开始购物
Apple Watch 套装
现在开始购物
1个答案
最有帮助的答案
JUST LOOK AT THEM
https://d3nevzfk7ii3be.cloudfront.net/ig...
这个答案有帮助吗?
按维修分数 1
评论:
And your point is? They are the same front speaker but they mount differently on the frame.
I'm talking about loud speaker, located on the bottom of the device. The one on Plus looks bigger and longer in size.
Definitely different.
Thank You very much. I will try to buy iPhone 6s Plus as I returned my 6s yeastaraday, maybe it will not experience the same issue with distorted sound.
添加一条评论
添加你的答案
Raimis 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 16
过去的30天: 57
总计 3,058
