跳转到主内容
Released on May 1, 2015 by LG. Can also be identified by LS770.
My phone won't let me add my Account
My phone is being really annoying I cant add my Gmail account br cause it is saying "Connot connect to Google servers Try again later" PLEASE HELP ME PLEASE
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
11条评论
Hi, Can you access the internet at all using the browser app etc?
完成的
Have you tried on both WIFI and Cell service? Also, simply shutdown/poweroff the phone and turn it back on. Restart may do it but cold start would be best (if you have not already). And a answer to @jayeff question would be helpful? Another thought does everything else on the phone work that is web based like the store app etc? Are you doing the initial setup of the device, if so try skipping and come back to it later.
Get back to us so we can help you more. If you solved your issue, please post what you did to correct the problem.
完成的
I haven't reset and I can use crome but it alwase say that I have to try again
完成的
without connection to internet you can not add an account
完成的
Mine is doing the same thing and it will let me use chrome but I cant use built in apps like youtube or playstore If anyone knows how to fix this please let me know
know
完成的
显示更多的6条评论
添加一条评论
1个答案
已选择的解决方案
Hi
Not quite sure where it is located in your phone but go to Menu > Settings > Apps > swipe right side to ALL Apps, then scroll down and find Download Manager. The Apps are listed alphabetically, with working apps first then disabled apps.
Tap to enter Download Manager. If there is an Enable button tap it then try to go online.
If it says 'disable' tap to disable, then tap clear cache. reboot phone then navigate back to Download Manager and enable it as above.
See if you can now access the internet with your browser. If you can try to add your g.mail account
这个答案有帮助吗?
得分 2
3条评论:
my phone do not show the download manager icon, what then do i do
完成的
it sure doesn't show the download manager button
完成的
@Bernadette Jackson
What is the make and model number of the phone?
Can you access the internet OK?
完成的
添加一条评论
添加你的答案
Jason patrkcm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 5,758
