跳转到主内容
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
86 个问题 查看全部
No network operations all of a sudden
no network connection of any kind,
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
PC 笔记本电池
An easy fix for a big power boost.
现在开始购物
PC 笔记本电池
现在开始购物
2个回答
Kind of need more info to help troubleshoot this.
Is there any damage to the device?
What was going on when connectivity ceased?
Is there damage to the SIM card?
这个答案有帮助吗?
按维修分数 0
添加一条评论
If it happens all of sudden, then this will be a software issue.
Problem may be of two type :
1- Software
2- Hardware
Software can be repair through Hard Reset, Just try the combination (Power + Volume up + Menu)
and if it fails then you have to Flash the device.
Download files from Samsung-updates.com
and check guide how to flash samsung android tablet
Hardware Issue:
If the software section fails to solve your issue, then you have to Change network ic.
(Use multimeter to check PCB)
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Christina Vasquez 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 43
