跳转到主内容
18 Dart Magazine / Rapid Fire Blasting / 85 ft range
3 个问题 查看全部
Why won't the slide on my Nerf Alpha Trooper move back?
When I get ready to load the device the slide won't move.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Two common mishaps can be the reason for this issue: either the gun has already been loaded or there is a dart stuck in the barrel of the gun. If a dart is stuck, insert a sturdy wire through the access gate and down the barrel to push it free.
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem, but there is no dart stuck, and isnt already loaded, the slide don´t move, I have disassembled the slide of the gun and I have discovered that there is a metal hook there, apparently it belongs to the pitcher because in the slide there is a hole for that hook, but the hook does not move, today I try to repair it and it crashed strongly against the I was able to move the slide but after giving the shot I stopped moving again, and I don't want to have to crash it every time to shoot.
完成的
添加一条评论
添加你的答案
Taylor Austin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 305
