跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
问题已关闭
back and front camera not work after screen replacement
hi,
i have a problem.
I changed the screen, the front and back camera now don't work.
I tried to reset the device in dfu mode but the problem exist yet.
The app of camera working because the button and the switch mode work perfectly but the screen stay black.
how can i fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello Fabrizio,
Sorry your having trouble. The front and back cameras operate off 2 separate flex cables and it's unlikely you could have damaged both. You might try disconnecting one at a time and see if one will function without the other connected. If you preformed a DFU then you have ruled our a software problem. That, in my opinion, leaves only one other possibility I'm afraid. It's quite likely you damages a SMD (surface mounted device) while lifting the flex cables from the board. It's easy to do if great care is not taken. That would require a board level repair.
Regards
Holger
这个答案有帮助吗?
得分 0
添加一条评论
i and how can rapair it ?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 61
