The Acer Aspire One 722 is a diverse netbook that was released in July 2008. The Acer Aspire One 722 is an 11.6 inch netbook that comes in a sleek black or blue color. This netbook weighs in at 1.46 kg, which is the typical weight of a netbook of its size.
9 个问题 查看全部
while installing my windows 7
Setup was unable to create a system partition or locate an existing partition?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
What caused you to reinstall windows? (What is the history of this laptop)
添加一条评论
1个答案
最有帮助的答案
You can manually prepare your hard drive:
BIG NOTE: This formats your whole hard drive, don't do this if you haven't backed up your data!
Boot the Windows Installer.
at the first installer screen press shift + F10 to take you to command prompt where you can run diskpart commands
type: diskpart - press ente (to enter diskpart)
type: list disk - press enter (list all connected HDDs)
type: select disk 0 - press enter (assuming disk 0 is the desired disk)
type: clean all - press enter (which will erase entire disk including partitions)
type: create partition primary - press enter (which will make one new primary partition the size of the disk)
type: format fs=ntfs - press enter (which will format the partition with ntfs structure)
type: active - press enter (to mark partition active so boot files can be placed on it)
type: exit - press enter (exit diskpart)
type exit - press enter (exit command prompt)
Continue the Installation.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Sasha Grey 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 91
