跳转到主内容
How do I take this apart?
This has strange, tri-shaped screw heads but not the same as the tri-shaped driver offered by iFixit. See attached representation.
How do unscrew these? Can I buy/make an appropriate driver?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
3个回答
已选择的解决方案
This may be a security screw. Please post a photo or take a look at the screws on this page and see if it's one pictured: http://www.mutualscrew.com/product/secur...
Do a google search for "tri-wing and security screws" and use the images option to see if you can find it.
这个答案有帮助吗?
按维修分数 2
添加一条评论
最有帮助的答案
Hi @cowboydon
I believe that it is called a Holt Head security screw.
Here is a link, scroll down to Holt Head and see if it is the one.
http://www.midstatesbolt.com/technical-h...
这个答案有帮助吗?
按维修分数 5
评论:
@jayeff Very good find
It looks like the Holt Head shown in the above link.
Hi @cowboydon,
Did you notice in the link that they also supply drivers for the Holt Head?
I have finally determined it is NOT a Holt head. It is a Torx T-8 security screw. Thanks everyone for your assistance!
添加一条评论
We have a couple of bits that would most likely fit it in the 64-bit driver kit. Does it look more like a tri-point or a triangle? We have 4 different sizes of tri-point and 2 sizes of triangle.
Mako Driver Kit - 64 Precision Bits张图片
产品
$29.99
这个答案有帮助吗?
按维修分数 2
评论:
It is not the triangle. I've also seen the tri-wing (like a 3 winged Phillips). It's not that either. The three points are on the outer edge of the screw head, equally spaced, but they do not connect in the middle as the tri-wing does. I figured out how to display my image (see my revised post).
添加一条评论
添加你的答案
donheath 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 3
总计 194
