跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
19998 个问题 查看全部
Dead Screen
After closing the lid on my MBP i opened it a couple of hours later and it was dead, like when you turn the brightness right down. I tried to restart with no success, still a blank screen, tried to plug in my external monitor with no luck. The external monitor does not recognise it and just goes to sleep.
I have been hitting up the internet for some leads, and most things point to the graphics card, NVIDA etc. Tried Resetting PRAM and NVRAM no luck.
Is there anything else i am missing or is it off to the apple store for me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Hi! Is it just an issue of the backlight (do you see a faint image of an Apple when you boot up and shine a flashlight through the Apple symbol from the rear), or is the screen completely dead? I assume it's completely dead. If it does not show an image via the external video, then I agree with your conclusion that it's probably the video card.
If you do see an image that is just not backlit, it could be the screen, the inverter, the inverter cabling, or the board, but no image at all, especially on external video, points to the GPU.
Just curious though, does the machine chime and basically act like it's functioning aside from the video, or is it frozen or otherwise in some abnormal state?
这个答案有帮助吗?
得分 2
1条评论:
Hi I am able to see content on Bright light(Sun Light) Its Only Backlight problem with my screen how can i fix it?
完成的
添加一条评论
From your description, it's not clear if the computer is functioning aside from the display. Have you tried booting to the system DVD or some external drive to rule out software problems?
这个答案有帮助吗?
得分 0
添加一条评论
If there is Nvida Chip you have a problem. Because of the Nvida chip heat more compair to Intel and Ati. It can be Problem. You have search the chip level repair. there the heat the Nvida Chip and Press. It work in 90% computer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,551
