跳转到主内容
修复你的物品
维修的权力
配件 & 工具
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
3021 个问题 查看全部
water damaged 4S screen gone black, won't display
My iPhone fell in a tub of fairly clean water and for about ten minutes it bubbled through the ear phone socket. The phone was retrieved and left in a warm room to dry out. Shaking the phone removed the water but the phone did not open to use. I connected it to my laptop using the cable and could charge the battery fully. The voice worked and it replayed. the volume control was also working.
The phone display was black; no display. How do I restore the gadget to work normally? Please help. Writing from India.
borudeb@gmail.com.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
最有帮助的答案
You will need to take the phone apart and clean it first.
Below is the tear down instructions.
iPhone 4s 拆解
Once you have the board out use a toothbrush and isopropyl alcohol to scrub any corrosion from the board and they connectors that attach to it. Reassemble and see if it works.
If the display does not come on you will need to try a new display to see if it comes on then. If the devices display still does not function with a new display then the board has suffered some damage that would require a special equipment like soldering iron. Even with this equipment and the appropriate skills it's not a guarantee that it can be repaired.
这个答案有帮助吗?
得分 1
添加一条评论
The mistake you made was plugging it in, and leaving it in the water for ten minutes. The corrosion on the board is probably too great for it to be repaired (unless you go professional, but I can't guarantee that it will work). The phone is pretty much a brick now. My suggestion would be to go buy yourself a newer iPhone or a phone of similar or better spec.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
borudeb 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 40
