跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
253 个问题 查看全部
iMac 20" A1174 dead, but +/-12VDC at PSU
Hi All !!!
Got an iMAC Model# A1174. 2006. 20" display. Last 4 of the SN are VU2S.
When you press the power button, NOTHING happens.
Disassembled the unit. What I discovered is: Power button tests good. If I DISCONNECT the multipin connector on the motherboard (logicboard?), then plug the power cord in, I hear the HDD spin up. No fans nor LEDs, just the HDD. if I re-connect the multipin connector on the motherboard, then plug the power cable in, nothing. Press the power button and again nothing.
Measurements:
With system normaled up but display and multipin connector removed I have the following on the PSU :
Grey wire 1 = +12VDC
Grey wire 2 = -12VDC
If I re-connect that multipin connector back into the motherboard, I get 0 VDC on those grey wires. With the multipin connector disconnected and the power cable plugged in, I can read various DC voltages (5, 3, & 12).
I have a bad feeling that the problem is possibly with the motherboard since the multipin connector has all the appropriate voltages on it before I plug it back into the motherboard.
Any ideas of how to test the PSU any further, or how to isolate this problem better?
THANKS ALL in advance!
Rob
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Any one else have any ideas?
完成的
@rms8 can you go on here http://www.everymac.com/ultimate-mac-loo... and identify your iMac for us completely?
完成的
添加一条评论
2个回答
已选择的解决方案
Well, it ended up being a defective power supply after all despite having good voltages pre load. Put a load on it (plug 14pin connector back into logicboard) and it would fail.
I'd like to give a special mention to eBay seller "atlantaecomm" {http://www.ebay.com/usr/atlantaecomm?eui...} for actually sending me a power supply, inverter board and logic board to test with. Without a known good PSU, I was convinced it was a faulty logic board. So thanks to Steve
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
@rms8 the very first thing you want to di is tell us what your diagnostic LED's are showing you.
The iMac (20-inch Late 2006) has three built-in diagnostic LEDs and a front power-on/sleep LED
on the main logic board that can help you to troubleshoot the computer.
To Access the Diagnostic LEDs:
1. Follow the take apart instructions to remove the RAM access door, front bezel, and lower EMI
shield.
2. Locate the SO-DIMM slot and LVDS video connector. The three diagnostic LEDs 1, 2, and 3 are
located below the battery and to the right of the memory slot. Note that the LEDs are
marked 1, 2, 3 as show below. An additional front bezel LED is located in an opening at the
center of the right speaker.
LED #1
• Indicates that the trickle voltage from the power supply has been detected by the main
logic board. This LED will remain ON whenever the iMac is connected to a working AC power
source. The LED will remain on even when the computer has been shut down or put to sleep.
The LED will turn off only if the AC power source is disconnected or the power supply is
faulty.
LED #2
• Indicates that the main logic board has detected proper power from the power supply when
the computer is turned on. This LED will be ON when the computer is turned on and the
power supply is working correctly.
LED #3
• Indicates that the computer and the LCD display are communicating. This LED will be ON
when the computer is turned on and video signal is being generated.
Front LED
• Indicates that the computer has power but no video signal (e.g., the computer is starting up
or the display has entered Sleep mode, turning off the video signal). This LED will pulse when
the entire system has entered Energy Saver mode.
To check the voltafge you may want to consider checking this great guide. Slightly younger model, but should still prove valuable.
这个答案有帮助吗?
得分 3
评论:
Thanks for the quick reply oldturkey!
Unfortunately, the iMac I have does *NOT* have the diag LEDs. Nor does it have that IC just to the left of them seen in your pic.
The Front LED does nothing.
The link you provided to measure power is for a newer iMac than what I have. My multipin connector is 7x2 (14pins).
Thanks,
Rob
完成的
Rob, see if there is a small piece of black tape on the bottom of the logic board to the right of the RAM slots. If so remove it to uncover the LEDs.
完成的
mayer,
I have attached a pic to my original post.
There you can see there are no LEDs.....
完成的
@rms8 I remember now the very first one of these did not have the LEDs. This makes diagnostics via the internet very difficult. That's why Apple added them. When you attempt boot what lights if any do you see and what sounds do you hear?
完成的
There is ZERO ACTIVITY. It behaves as if it is unplugged. I have determined it must be the logic board since :
A.) I see all voltages on the end of the 14pin connector when it is UNPLUGGED from the logicboard.
B.) The HDD spins up when the 14pin connector is UNPLUGGED from the logicboard.
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 555
