跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
424 个问题 查看全部
How do I find reactivation code for radio
My car radio is deactivated and u don't know my code to reactivate it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
10条评论
You can get a radio activation code here: https://radiocodevault.com/honda
完成的
That site is a scam. You dont have to pay $@$*. https://radio-navicode.honda.com. got a free code.
完成的
Ended up getting my radio code from https://radiocodevault.com/honda/ for my honda odyssey, works on all models though. Great service, and gave me a working radio code. Don't know what the commenter above is complaining about, cheapskate I guess. I wanted a solution that actually WORKED.
完成的
www.radiocodevault.com unlocked my honda. Gracias everyone.
完成的
2000 Honda Accord stick 4C radio code
完成的
显示更多的5条评论
添加一条评论
3个答案
已选择的解决方案
@amelia1 there are a couple of things you can try:
1. Look in glove box for small sticker with numbers, should be 5 digits with numbers no greater then 6.
2. Pull out the ashtray and see if the sticker is on the back of there.(older models that have them)
3. Pull radio from dash and write down radio serial number and call local dealer with that number and they will be able to get the code for you. They will ask verifying questions.
One more thing you can do is that Honda has a radio reset website, this is an automated service that can provide your Honda stereo code. Just write down the serial number of your radio and the VIN number of your vehicle then contact Honda. The VIN number is located on the driver side of your Accord vehicle just behind the windshield.
You could also give this a try:
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn car to ON II(radio powers up)
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn radio off
Hold 1 & 6 buttons on radio
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)While still holding 1 & 6, turn radio on
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Write down the 8digit number that should display
Call your Honda dealer and give them those numbers.
这个答案有帮助吗?
得分 6
添加一条评论
I got my activation code from https://radiocodevault.com/honda/
这个答案有帮助吗?
得分 1
添加一条评论
I don't know how battery was dislocated radio off not great with technology or tools need code 1998 honda accord CV ord
这个答案有帮助吗?
得分 0
1条评论:
Not good with none of the technology
完成的
添加一条评论
添加你的答案
Amelia davila 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 104
总计 41,317
