I have had this happen in the past. If the drive is not lined up perfect when being put back together, it will be misaligned and wont accept disks in. When it didn't accept them in, it would click and cluck trying to take the disk in but since it was out of alignment it never goes in.
One good question is.... did it accept disks before you took it apart. If it did, then it should be a simple fix. If not, then it could be a previous person working on it, or the drive's circuitry is messed up.
One fix is to take the drive apart and try to get everything lined up and happy again. It takes a few times to get it right, but you should be able to look at photos or videos of opened drives to see where everything should be.
Worst case is to replace the drive even though I'm pretty sure it isn't bad.
Good luck, and let us know if you get it working.
6条评论
There is a magnet inside that is out of place
由 Day Boi 完成的
Mine was weird, I was playing it and all of a sudden I froze in a game. I turned the system off and back on and found that I was not able to see the disk in the system anymore. Almost like a modder had shut my system down on me without my knowledge. I have heard of this happening to other people in the past however I have never experienced it myself. I am unable to reload a disk into my system and also I am unable to get on youtube, HULU, or Netflix. Each time I try i get sent to the black screen and then nothing else happens. Have to restart the system again. I am able to talk to friends with messages but other than that its just a black brick taking up space. How do I fix this problem.
由 Brian M Willoughby 完成的
@destroyerfne did you ever fix your ps3 issues? I’m having the same ones
由 trainhoppersin 完成的
@trainhoppersin same here...
由 Gaby Cove 完成的
same here ...
由 chad jeanveau 完成的
显示更多的1条评论
