跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2189 个问题 查看全部
问题已关闭
Black screen after screen replacement
I replaced my iPhone 4S screen and after that the phone turns on, but nothing appers on screen but the backlight is on, what i can do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
4S screens often have "compatibility" issues meaning some screens work on some phones or iOS versions but not others.
The other reason could simply be a bad screen or botched install that caused damage to the screen flex cable.
Finally, it could be a bad install meaning the screen cable is not properly seated (unlikely since you have back-light) or some component is damaged where you plug the screen cable in.
To determine the cause, try the old screen back. If it works normally, you have to get another known good screen from another source e.g. another version.
If old screen doesn't work, you have board damage unless you also damaged the old screen during re-install.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for helping! but I need another replacement screen, I updated the iOS from 7.0.4 to 9.2.1 and still nothing on screen. The cables are properly seated on the board, I do not have the old screen because the flat cable broke when i removed. I think I busted the cable when installing, I think the board is ok, next week I will give a try. (sry for the bad english, I am from Brazil)
完成的
添加一条评论
Double check the LCD and Digitizer cable at top of logic board. See if it's clicked in fully. If not, screen most likely no good due to not being put on properly.
这个答案有帮助吗?
得分 0
1条评论:
I already checked :/
完成的
添加一条评论
I had the same issue. Needed to be put in DFU mode and then restored via iTunes.
这个答案有帮助吗?
得分 0
4条评论:
Tomorrow I will give a try :D
完成的
Did you give it a go and did it resolve the issue?
完成的
No, i have a bad screen.
完成的
Sadness :( .
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 121
