跳转到主内容
This is a homepage for the iDevices iGrill 1st Generation. Here, you will find links to the troubleshooting page, as well as images of the device.
3 个问题 查看全部
How can I pair my iGrill via Bluetooth?
I'm having trouble connecting my mobile phone to my iGrill, could anyone explain how to do this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Turn on iGrill and make sure that blue Bluetooth light is blinking, otherwise refer to troubleshooting page. Turn Bluetooth on on your iPhone, iPad, or iPod touch. Make sure you have the iDevices app or download it. Go to the iDevices app, tap on the 'search' button, the app should be able to find your iGrill. Tap on the 'connect/pair' button. Your iGrill is now connected, and you are ready to start monitoring with your remote device. See this link for more info: https://www.youtube.com/watch?v=1RW_A-I9...
这个答案有帮助吗?
得分 1
4条评论:
Actually it isn't the iDevices app you need. It is the iGrill app from Weber that connects. This may have changed since the original question and answer.
完成的
Support for the original iGrill has apparently been dropped by Weber in recent versions of their (horribly updated) app. Call them and complain. One user reported they sent him a newer device to replace his "obsolete" one.
完成的
I wish I would have seen this an hour ago,,, I've been jacking with the iDevices trying to get it to pair. Finally just downloaded the iGrill Webber and it synced in 1 second.
完成的
I recommend (for the original iGrill) that you remove the batteries after each time you use it and insert them when it's time to sync and cook again. When the software supported that model, it connected much more reliably.
完成的
添加一条评论
添加你的答案
Kyle McElyea 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 40
总计 22,709
