跳转到主内容
修复你的物品
维修的权力
商店
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3419 个问题 查看全部
iPhone 5 only works with the original screen?
Hi people,
Had a really weird phone this week, an iPhone 5 with broken glass.
The lcd was still working, so was the touch. I have tried to replace the screen but every screen i tried to put on did not work properly. The lcd's turn on for about a sec, then faded away. Some screens gave only a black screen but the backlight turn on. I even tried some original ones with broken glass I had from previoius repairs but they also did not work.
Only the original one that was on the phone when i got it worked? what could be the cause of this?
After 2 hours I gave up and told the customer to go to a repair shop where they replace glass only.
Anyone had this problem before?
thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
评论:
Wow! The first thing I would suspect is a previous repair or alteration and it's not what it says it is.
完成的
She told me she bought it brand new and I was the second repair shop she visited. The first one also told her he could not fix here phone. Everything looked fine and original to me... really weird
完成的
I had the same problem with iPhone 5C work only with the original screen and touch didn't work. I give up on this one and give it back to the customer.
完成的
添加一条评论
2个回答
最有帮助的答案
See this article on identifying fake iPhones: http://www.ebay.com/gds/How-to-Spot-a-Fa...
这个答案有帮助吗?
得分 1
评论:
I'm
sure it was a real iPhone, but i was referring to the screen
完成的
Why the down vote? I've even has a couple of fake Macbook Airs come in?
完成的
Sorry mayer, just because maybe a fake one is not the answer
完成的
添加一条评论
I've never seen anything like that. I'm pretty sure that you tried two faulty screens or they where not properly connected. The phone is not supposed to recognize if the screen is original or not.
这个答案有帮助吗?
得分 0
评论:
Hi James, I tried about 8 different new ones. And 3 originals with broken glass from previous repairs. None of them worked. I've done a lot of repairs the last 3,5 years. So I'm also sure they were properly connected. Never seen anything like it... :-(
完成的
添加一条评论
添加你的答案
ifixshop 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 177
