苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3833 个问题 查看全部
My battery life drain on standby
what is the different between
ic u2
and
ic power
what's the problems for both ?
my problem battery life drain on standby even after battery replacement ..
I'm sure it's hardware problem
any idea
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
2个回答
ic u2 functions is management the data transfer, charge, and boot
ic power functions is supply power to all ic
battery drain common there are have short on the machine ic or capasiotrs
这个答案有帮助吗?
按维修分数 0
评论:
Can you tell me what should i replace to fix battery drain
添加一条评论
Iphone 5s.Have the same issue after battery replacement, find a temporary solution.
when Disconnected Home button flex cable from logic board, battery drain stopped.
Tried many different home buttons but when connected battery draining started again.
Actually I also changed home button and charing socket nothing changed. The phone still draining battery while on standby except home button flex cable departed from the socket.
Couldn't find different solution
Any idea what the problem is?
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Omar 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 176
