跳转到主内容
这是2013年Lightahead DV328高清720p摄像机的设备页面,具有4倍数码变焦和2.7“翻转屏幕
My device won't charge when plugged in?
I checked to make sure that there wasn't anything wrong with the battery and found that it is the correct battery. However, the device will not charge even when it's plugged in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
The charger could have a malfunctioning cord. Check to see if there are any tears within the wire. Sometimes there are rips where the plug is located. If this is the case, a new charger will be needed.
这个答案有帮助吗?
得分 0
添加一条评论
Probably a BIOS problem. You need to roll back the BIOS to an earlier version. There is one stored on your machine, but to access it, you need to go to "BIOS Setup"....probably press F12 as you power on, or if it gives you an error message on powering up that the adaptor " is not recognised", press "' BIOS setup"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexandra McMurray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 242
