跳转到主内容
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
10 个问题 查看全部
Why isn't my device turning on?
I've held down the power button and it isn't turning on, no matter how long I hold the button down for.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Hey, my 4 year old sister LeapsterGS won't turn on. I've tried doing new batteries it still won't work can you please help or do you know something about it??? AND, I've lost the charger that came with it... Thanks!
完成的
添加一条评论
3个答案
已选择的解决方案
I'd start by making sure the battery is charged. Try plugging it in using the adapter and cord. Be sure that you double check the connections between the adapter and the wall and the cord and the device. Make sure that they are both connected securely or the device will not charge and this is a common mistake.
If the LeapPad still won't turn on, it could be that the battery is dead. At that point in time, all you can do is replace the battery.
It could also be a malfunction with the power button or an issue with the software, but I'd make sure it's not the battery before anything else.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
How old is it? Is it still under warranty. Are you sure the battery is charged up? Do you get anything on the screen? http://www.leapfrog.com/en-us/legal/warr...
这个答案有帮助吗?
得分 2
添加一条评论
Try New Batteries!
Or charge it with the charger that came with it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Saso 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 51
过去 30 天: 204
总计 12,456
