跳转到主内容
A 5-speed hand mixer released in 2012. This mixer includes beaters, but supports several attachments including a whisk and dough hook.
6 个问题 查看全部
Beaters keep falling out!
Every time I try to mixes anything harder than average beaters fall out of the mixer after a few seconds of working. Is there anything I can do to make them stay in the mixer (no I don't press the eject button accidentally).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
I have bought 2 of them and the same thing happened both times. The beaters made a funny sound like they were hitting each other. Then quit working. One I used for awhile and the 2nd one I only used about 1 time. Will never buy this again.
完成的
My beaters keep falling off too. Disappointed in Staten Island, NY.
完成的
I've only used mine 1 other time and it's already doing this for me as well. I went to use for a second time after just buying it and one beater kept coming out. Will never get this brand again!
完成的
添加一条评论
1个答案
已选择的解决方案
When you plug your beaters make sure you can hear a “click” noise that assures they are plugged in all the way. If there is no noise when you stick the beaters all the way, the tabs could be broken. Examine the beaters for damage to the tabs, replace the beaters if necessary. If everything is good with the beaters, the mixer’s spring that holds the beaters could be damaged and it will need to be replaced.
Check out the section on beaters falling out on the KitchenAid KHM512ER Troubleshooting Page .
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Yuriy Zaynulin 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 34
过去 30 天: 194
总计 19,626
