跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
95 个问题 查看全部
car radio wont turn on
the radio isnt working even after changing the fuse , anyone know why ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
You'll need to get a radio code to unlock it. You can get a radio code here: https://radiocodevault.com/honda
Hope it helps mate
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
If the power has been removed, by changing the fuse for instance, then a security code may have to be re-entered to get the radio to work again. The code was introduced as an anti-theft device used to render the radio useless if it was stolen.
That is why when car batteries are being replaced they usually power the car through the cigarette lighter power outlet to maintain power to the radio and nowadays probably other electronics so as to maintain their settings.
The code may still be on a sticker or slip of paper in the car's owner manual.(if you still have it and if the code hasn't been changed at all).
If not then there are services online that will provide the unlock code and user instructions for a fee. Just search for reset Honda car radio after flat battery forgot code or something similar.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mannat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 45
总计 3,595
