跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why my screen is Blank?
Hello Guys!
I have an iphone 6 with Blank screen i also tried Force Restart bay Holding Home Button+Power off/on Button But it still Blank.
When i Connect it to Computer itunes open automatically and shows my iphone 6 64GB.
'''(Before This Problem It is also shows Error 53 while Restoring/Updating
And Now Error 53 is Fixed)'''
I reconnect the Front Panel But Problem is Not Solved Please Suggest me
What to do for this Problem to get it Solved.
Sorry For bad english
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your problem is "no display" meaning you have to test the phone with a new screen assembly. If it works, you had a bad screen. You can have it done at a repair store or DIY after getting a screen here or a complete assembly here.
If not, then the phone is not giving out an image. In which case, more info is needed. Is the screen is blank=whitish or actually black? Before it had this error, what was the history? Why did it have error 53 to begin with? Was the screen replaced? Or subject to some other repair attempt? Was the device liquid damaged? Details will be needed to help understand the root of the problem to try and fix it.
iPhone 6 Screen图片
产品
iPhone 6 Screen
$44.99
iPhone 6 LCD and Digitizer图片
产品
$69.99
这个答案有帮助吗?
得分 3
添加一条评论
It's my understanding that the Fingerprint/Home Button without un-enrolling your fingerprints and disabling the fingerprint feature, the phone gets bricked within a month. Did you have your LCD Assembly replaced since you've owned the phone? The best-practice is to preserve your old home button at all costs, even if the button is in trouble.
I'd recommend downloading your IPSW file from iClarified, then holding down Option or Shift, and clicking Restore iPhone from within iTunes. Specify the big file when asked, and see if that helps.
IPSW files:
http://www.iclarified.com/750/where-to-d...
Apple Error 53 says on Apple's Website:
Errors: 1, 3, 11, 12, 13, 14, 16, 20, 21, 23, 26, 27, 28, 29, 34, 35, 36, 37, 40, 53, 56, 1002, 1004, 1011, 1012, 1014, 1667, or 1669.
Your device or computer might have a hardware issue that stops the update or restore from completing.
Check that your security software and settings aren't blocking your device from communicating with the Apple update server.
Then try to restore your iOS device two more times while connected with a cable, computer, and network you know are good.
Make sure that your security software and settings are allowing communication between your device and update servers.
If you still see the error message when you update or restore, contact Apple support.
If you still see the error message, check for outdated or modified software."
这个答案有帮助吗?
得分 0
2条评论:
Error 53 is Already Solved in iOS 9.2.1(13D20)
My main Problem is Blank Screen when i connect it to computer it vibrate ever few minute
完成的
good point - has any repair work been done on this phone before?
完成的
添加一条评论
添加你的答案
Faisal Joiya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,023
