跳转到主内容
Kyocera's Hydro Vibe is a waterproof touch screen phone with a 4.5inch impact-resistant screen and Smart Sonic receiver technology
15 个问题 查看全部
问题已关闭
What might cause short battery life?
My Kyocera Hydro Vibe is having issues with its battery life. The battery life started to deplete rapidly and now the phone will not stay on for longer than a few seconds after charging it for an extended period of time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
yüksek ihtimalle pil bozulmuş ama cihazda da sorun olabilir, yeni bir pil ile dene
这个答案有帮助吗?
得分 0
添加一条评论
You can try to restart your phone, once in a while you have to restart your phone because it can counter a common issue. If that doesn't work, you can close your unused app on your phone that might drain your battery. You can also check your battery, you might need to replace your battery. You can also go to the troubleshooting link ---Kyocera Hydro Vibe Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 315
