跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
screen cracked and phone body bent
I dropped my Iphone and the screen is shattered. all functions still work as I have a really good screen saver that is not broken so I think I can just replace the glass screen. However, the body of the phone is bent so it is no longer flat. once I remove the screen will I be able to bend this back into place so the new screen will fit properly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
gövde eğilmiş ise anakart muhtemelen bozulmuştur, yeni bir telefon alman bence daha sağlıklı olur
这个答案有帮助吗?
得分 0
添加一条评论
Yes, you can bend back Iphone frames. Look for youtube tutorials.
BUT, bending metal will decrease strength and could break it. So be careful.
这个答案有帮助吗?
得分 0
添加一条评论
you should be able to bend it back as long as it does not affect the circuit board and as long as all clips for the screen and screw hold line up there should not be a problem. How badly is the phone bent?
这个答案有帮助吗?
得分 0
添加一条评论
hello from experience I can say that separate the display from the glass is not easy if you have not experienced a minimum and you can buy for 50 € + display glass. while for the homes it is very folded it is difficult to bend, then you should take it back € 30 million without wiring and comprehensive € 45. to make these interventions there are guides on the site but you have to be a little 'expert and have manual skills and courage. good repair
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
boatswain2385 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 3,124
