跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
3D touch after screen disassembly
Hi.
So, I read that the 3D touch won´t be perfect after a screens replacement. Is this right?
Any different between a OEM screen and a original?
And, if I disconnect the screen (original screen that came with the phone), and connect it again, will that affect the 3D touch?
-Alex
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
5个答案
最有帮助的答案
Not all support the 3d touch function well. We have made a test on different iPhone 6s screens about 3d touch. You can check here:
此嵌入似乎无效。请检查URL。
这个答案有帮助吗?
得分 1
添加一条评论
Yea, it’s a little weird. I can’t switch apps anymore, there is a dead spot in a certain section of the display and half the time it fails to register at all.
All that to say, I feel like I got what I paid for. The display works. Touch feels accurate. Colors are solid. Refresh rate is slow, resolution is lower than original and force touch isn’t fully functioning. But I can text again!
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
I have ordered my replacement display from iFixit.
The viewing angel is poorer then the original Display. It was like switch the phone on and recognizing that there is something different. Refresh rate I can’t comment.
But what is really annoying is the 3D touch! I use it regularly when typing text to move the cursor.
For me it seems that the display actually does not have an force touch, instead my impression is that is simulates it by detecting an increasing area that is touched.
So when I use the flat thumb it works, but if I use only the tip of the finger it does not! On the original it always worked with the finger tip. Another indication is that the sensitiveres in the settings has no effect.
I’m hoping for a reaction of iFixit.
/Oliver
这个答案有帮助吗?
得分 1
1条评论:
I have this same issue. Third party replacement screens with 3d touch works exactly as you described, by detecting a large area and not pressure. I've tried multiple screens from amazon all with same result.
is this wrongly installed, or are all the screens like this unless you get it at apple?
完成的
添加一条评论
OEM 6s displays are built in a different factory, which means they will have different workmanship from the original displays.
It may look the same and feel the same but the 3D touch may not be as responsive as with the original.
这个答案有帮助吗?
得分 0
添加一条评论
What do you mean it wont be perfect?
Ive gotten my 6S Screen/LCD repaired myself ( same LCD, i just repaired the glass screen) and the 3D touch works fine.
这个答案有帮助吗?
得分 0
2条评论:
It all appears to be down to the individual quality of the parts. I ordered a 6S LCD for a screen replacement and while the LCD and touch worked without a problem , the Force Touch would only work 30-50% of the time and be really inconsistent.
In the end , I got a refund on the screen! , probably like most things there are varying quality of the parts. Where did you source yours from and how much did you pay for it if you don't mind me asking? :-)
完成的
Where did you bought it?
完成的
添加一条评论
添加你的答案
alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 7,135
