跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
问题已关闭
HELP! Touch screen not responding after water damage.
After leaving my water bottle in my bag, my iPod got wet. Stupid of me, but I left it on and tried to check if the music still worked. After awhile, I tried to turn it off, but the touch screen wouldn't work. So I left it in a bowl of rice for a couple of days and found that the iPod turned on and everything was great until I tried to unlock my iPod. I again put it in rice (thinking that the water that had not been absorbed by the water would be absorbed), and the touch screen is still not working!! I then tried restoring it, which was just a pain in the butt and my iPod won't restart for some reason >.<.
Any pointer/suggestions? Should I put it in rice again? Or should I just fork up the money to get it repaired by Apple or any other company??
Please and thank you!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
yo mommas so fatttttttt
这个答案有帮助吗?
得分 3
1条评论:
and "yo momma" did not teach you any manners
完成的
添加一条评论
You should try replacing the front panel / digitizer assembly (which contains the touch sensor).
iPod touch (Gen 2) Front Panel Assembly图片
产品
$29.99
这个答案有帮助吗?
得分 1
添加一条评论
I've replaced the front/panel digitizer assembly however, i'm stuck with same issue. Touch screen is still not working. I've done almost everything i can...I'm starting to think i'm "SOL" or is there anything else i should try....please help
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 7,101
