跳转到主内容
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 个问题 查看全部
Camera won't switch to different lighting settings
I brought my instax mini eight out for the first time to take a couple pictures on a hike, and when I went to adjust the lighting from indoor to cloudy, it didn't change. The orange light switched between all of the settings without me turning the dial, and eventually became stuck on the indoor setting. Can the camera be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
5条评论
umm what if the lighting setting/the adjustment for the lights does not flash
完成的
My film wont came out and the censor light wont turn down even when i shut the camera down, how can i fixed it ? :(
完成的
my light doesnt change to any of the icons it just stays on "home" icon, I JUST GOT IT OUT OF THE BOX
完成的
My problem is that, all of the icons are all lighted? How can I fix this? Please I badly need help. Thank you
完成的
I had the same problem! It may be just a mechanical problem but if you look closely at the lense, you will see that it still opens and closes with each dial turned. The orange light is just showing what its on but with that broken, the whole thing still works. The lense with the biggest opening brings the most sunlight and the smallest opening is the darkest setting. Hope this helped!
完成的
添加一条评论
8个答案
已选择的解决方案
I don't think the camera is broken to begin with.
The orange light next to the exposure dial suggests the correct setting of the dial, it isn't supposed to change when you turn the dial. You just have to turn the dial so it matches the light.
The correct procedure is to point the camera in the direction of the subject, then turn the dial to match the light. Also, on the front of the camera next to the flash window there are two small round holes, be careful not to cover these with your fingers when you hold the camera: these are the light sensors, and they cannot work correctly when they're covered.
这个答案有帮助吗?
得分 18
6条评论:
Its causing my photo quality to be bad or faded because its so sunny where I am at.
完成的
Thx so much It really helps me bc I thought mine was broken this lets me know that some people are also having this problem that can be solved
完成的
What if the light on the dial won't turn on
完成的
thank you so much, It never did that before so I thought it was broken.
完成的
I tried it in a really dark place and then outside when it was sunny, and the light dial still the same. This causes my photos to go dark, is annoying.
完成的
显示更多的1条评论
添加一条评论
thank u!!! this really helped
这个答案有帮助吗?
得分 2
添加一条评论
thank you so much!!!!!!!!!! I thought my camera wass broken bc it wouldn't switch light positions, but now i know it is fine.
这个答案有帮助吗?
得分 1
1条评论:
but i had this since last christmas, it was like thaat as soon as i opened it, and even in the sun it does not change dials or settings...
完成的
添加一条评论
Thank you so much!!!! This really helped
这个答案有帮助吗?
得分 0
添加一条评论
Omg this makes so much more sense thank you so much.
这个答案有帮助吗?
得分 0
添加一条评论
I put my new film in the instax mini 9 but the S is not changing to 10 and it is not taking pictures.
这个答案有帮助吗?
得分 0
添加一条评论
Wow! Thanks, it makes TOTAL sense. I was already thinking the camera was broken!
这个答案有帮助吗?
得分 0
添加一条评论
Oh wow I was having the same problem with my instax mini 9 and also though it was broken Thanks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly Giordano 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 116
过去 30 天: 510
总计 133,650
