跳转到主内容
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
114 个问题 查看全部
Touch-screen not working after instaling vibrator motor.
So I had a problem with my vibrator motor, so I ordered a new powerbutton/vibrator motor assembly. I installed it, but it's still not working. But I now created an even worse problem. Now my touch-screen doesn't work at all. It turns on no problem but it doesn't register touch. Did I not plug something in? The only two plugs I see are the one of the bottom right (that has nothing to do with the power button/vibrator assembly, and then theres the one that connects from the motherboard to the bottom left of the phone.
Which one registers touch and which one shows the image?
Any ideas on how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi Max
There should be digitizer connector that goes into the flex on the lcd and if I am right the LCD connects to the motherboard with only one connection. If these are damaged the touch wont work.
Hope this help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 92
