Samsung's 8GB MP3 player running Android OS. Can also expand memory with a micro SD card. 4.2" screen. Has wifi and bluetooth connectivity and a 3.2 MP camera in the rear and a VGA camera in the front.
I installed the battery on my galaxy S3 just to check if it worked. Phone booted fine and stayed on and listed 90 % charged. So I'm back to player, it boots but as soon as I try to use it it shuts down like when the battery is low and can't run the device.
bad batterie maybe? i always order 2x the item i need to replace if one show some issue is try the other one if other one gives same issue you know it's somthing else then the replacing part.
由 Joe 完成的
