跳转到主内容
Keyboard wont connect to tablet
Keyboard will not work after I connect it to my tablet
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
The HDMI port must be enabled for the keyboard to work. Go to display and check HDMI.
这个答案有帮助吗?
按维修分数 6
评论:
Thanks, that did the trick!
That worked. Glad to see an expert that actually knows what he's talking about. Thank you!
Thanks for the hdmi info. Learn something new every day:-)
Thank you so much! I've been without a keyboard for over a year now. Rca sent me several replacements; some worked for a short while, some didn't work at all. Your solution did it! You are my hero!
I have the same problems but i went to display and im not seeing anything that says hdmi
显示更多的1条评论
添加一条评论
you may need to reinstall the drivers or check the docking port to make sure the docks are both clean and have no lint as this has been an issue with this 2 in 1. hope this helps
这个答案有帮助吗?
按维修分数 2
评论:
How do I reinstall the drivers. I bought a different keyboard cause mine quit working, now the new one won't work......Help......
添加一条评论
Trouble shoot and reconnect the keyboard.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 29
过去的30天: 105
总计 7,100
