跳转到主内容
Model A1285 / 8 or 16 GB capacity
206 个问题 查看全部
my Ipod got wet, I dried it off. Why does it only work when charging?
My Ipod went through the washing machine and wasn't in a case. I thought it was a goner but I put it in uncooked rice for a day or two anyways. I tried turning it on after two days and it wouldn't so I plugged it into my pc cable charger and it powered up. All my songs are still there, it works fine. When I unplug it from the power it continues to work for about two minutes and than the screen goes black. What do you think the problem is? Would you reccomend taking it to an ipod repair shop or is this something that can be fixed at home? I'm a tech wizard and so is my dad so please suggeest anything that may help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Whenever a Li-ion Battery gets water intrusion, the battery is a goner.... Lithium in its natural state is HIGHLY reactive to water, therefore, you loose ALL charge and ability to recharge..... Replace the battery.... (Aviation Electrician - USN)
这个答案有帮助吗?
得分 2
添加一条评论
you could open it up and try to let it dry out some more to see if that helps. I had a cellphone survive the wash but it only came back fully to life after 5 or more days of drying out while disassembled.
however because you say it works when plugged in but only lasts a few minutes on battery, I'm guessing maybe the battery has been damaged or shorted out internally or otherwise suffered an early death (unless your battery was already dead) - perhaps you will simply need to replace the battery with a new one.
but I would disassemble it, try to let it dry out further (again in rice would be good), then if it still fully functions plugged in but not on battery try replacing the battery. good luck
这个答案有帮助吗?
得分 1
添加一条评论
yes replace the battery
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kingzuda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 6,803
