How do I replace the battery in the LeapFrog Platinum?
How do I change the battery? The company says it cannot be replaced but I want to know for sure.
I'm assuming you want to replace the battery because you are having issues with battery life or because your LeapPad won't turn on. May I suggest checking out the troubleshooting page to rule out a simpler solution before you tear your device apart? The battery is kind of a pain to replace so I want to help you avoid that if I can!
If you determine the battery does indeed need to be replaced, it is possible to do so. My team and I will be writing a battery replacement guide very soon, so keep a look out for that!
这个答案有帮助吗?
The battery replacement guide is updated, you can check it out now.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,743
