Wi-fi problem off/on and I can't fix it
Hey I have a Samsung Galaxy Tab 2 7.0 and the wi-fi is turning itself on and off
Someone can help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
Hi Yonu
Can you restore the tab to factory settings that may help.
Keep me posted. Thanks
完成的
I try this isin t work
完成的
Maybe you need to flash new software or it may be the wifi IC. It is hard to say when you don't have the device in your hands to test it. Sorry I could't help and good luck.
完成的
Is the same thing with Obtaining WiFi Address
完成的
Your problem is that you cannot get the Wi-Fi to stay on all the time, so it maybe a hardware issue. If it is on you can see if your tab can find Wi-Fi points and you can see if can connect, when trying to connect then is obtaining Wi-Fi address. But if you cannot keep it on you cannot see if it get to the point of obtaining Wi-Fi address. I am not sure if you could understand what I am trying to say. Sorry about that
完成的
添加一条评论
