跳转到主内容
修复你的物品
维修的权力
商店
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4084 个问题 查看全部
fast discharging of the batterie
Hey there,
I got a used IPhone 5S from a friend. He gave it away because it discharges completely in under 2 hours. While the phone is on without any process it is also really hot.
I read that a reset to default setup may help. But it is the same after it in the clean start enviroment.
Is it really the battery by themselves or is there any component that could have a short circuit or something like that?
Thanks a lot for your help.
Anton
Update (14.02.2016)
After changing the batterie the behaviour is the same. Is there any possiblity to identify the component witch is the reasen for fast discharging?
Battery I bought:
http://www.amazon.de/gp/product/B00LZNS0...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
Could be the battery definitely worth attempting replacement. However, if it's getting hot as well it could also be the PM IC (Power Management IC) or U2 charging IC both chips would be board level repairs.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AntonB 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 174
