跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
638 个问题 查看全部
Galaxy S5 G900 display works on Galaxy S5 New Edition?
I need to know if the Galaxy S5 G900 display are the same or can work with my S5 New Edition. Don't exist specifically "S5 New Edition display" in my country, and don't worth for me to bring it from another country.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个回答
已选择的解决方案
There appear to be some small differences in shape and ID tags on the flex cables.
Good new is to be safe you can find the Neo versions on ebay and other sources;
http://www.ebay.com/itm/like/18204441381...
这个答案有帮助吗?
得分 1
评论:
The dollar exchange is really prohibitive. Cost 60% of a new one and it takes more than 2 months to deliver in my home. Thanks for the help.
完成的
https://budgetelectronics.ca/product-des...
Budget Electronics is Canadian distributor that the company I work for uses. They're great to work with. If they don't have an item listed that you're looking for, you can contact them and they will find it! They procured the S5 Neo LCD + Digi for me when I ordered a standard S5 from them when I assumed an S5 would be compatible.
完成的
添加一条评论
最有帮助的答案
Hi,
Here is a link which shows the model numbers for all 42 Galaxy S5 models. With this you may be able to find out if the G900? display is compatible with your S5 New Edition (also known as Neo).
Hopefully this is of some help.
http://androidforums.com/threads/42-gala...
这个答案有帮助吗?
得分 2
评论:
The model is G903M. The available display is G900H or G900F.
完成的
添加一条评论
Could you gather more information on this Russo? I've got the same problem right now. My S5 neo needs a new display and i can only get my hands on a S5 display atm.
这个答案有帮助吗?
得分 0
评论:
I asked to some sellers and the answers are not satisfatory: Some say that works, and some don't. I really don't trust in local technicians or sellers, here in Brazil they just don't know what are doing in most cases.
完成的
添加一条评论
I currently have an S5 Neo I'm attempting to repair. I could only get my hands on S5 LCD + digis. I'm attempting the repair but the connector cables are slightly different. I fear forcing it may damage. So my guess is that they are not compatible? Any confirmations?
这个答案有帮助吗?
得分 0
评论:
Confirmed myself that a Samsung Galaxy S5 LCD + Digitizer does not work with a Samsung Galaxy S5 Neo. The connectors are slightly different. The glass and the digitizer are the right size, but the connectors are different. Keep that in mind when looking for parts.
完成的
添加一条评论
Greetings i ordered a G903F lcd & digitizer on ebay for my G903M which the spec are the same but yet still it did not work, no display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Russo 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 13
总计 6,970
