跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6, why won't turn on after home button replacement
Today i replaced the home button and cable on an iPhone 6 actually the problem was home button was unresponsive only. Now fitting the new cable to the phone i found i couldn't get the phone to turn on and only disconnecting and reconnecting the battery after refitting the original cable got the phone is still unresponsive.
I run out of ideas, any suggestions from you wise people?
thanks in advance
rahul
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Any one, can you please give me a full schematic diagram of my i phone 6
完成的
添加一条评论
3个答案
You cannot replace the home button on the iPhone 6. Restoring will lead the phone being completely useless.
If you still have the old home button, reinstall it. Try replacing the extension cable that goes behind the metal backplate instead.
这个答案有帮助吗?
得分 0
6条评论:
Thanks for replay jake I replaced the old home button and cable Still same problem unresponsive now its fully dead I din't try restore via itune
完成的
Did you detach the battery connector before repairing?
完成的
I don't detach the battery connector before repairing
完成的
Well if the phone turned on during the repair, connecting connectors would short the components themselves. You might have shorted your home button or a components on the phone itself.
完成的
jack, can you please give me a full schematic diagram of i phone 6
完成的
显示更多的1条评论
添加一条评论
Rahul,
Did you connect your iPhone to iTunes? If so, you may have triggered Error 53.
You can learn more here: http://ifixit.org/blog/7889/whats-up-wit...
这个答案有帮助吗?
得分 0
2条评论:
Only if he restored it through iTunes.
完成的
I din't try restore via i Tunes .
完成的
添加一条评论
You can replace the iphone 6 home button and cable without it being a problem( Its possible to replace the 6s also but if you replace the button you lose fingerprint control)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hulk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,857
