跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
Stuck in a reboot loop after repair
I put a new frame on my iPhone 5s and put it all back together. I had it working except the screen didn't want to rotate so I took the front screen of again to try to solve these problems. I reconnected the LCD cables and home button and now I am stuck in a reboot loop, and my screen has a horrible line down the middle. I have had this problem before and I figured out it was just the screws being in the wrong holes on the LCD cable shield. I had the screws in the right holes but yet I am still in a boot loop. I currently have the shield remove from my iphone and it's still in a boot loop and it won't restore on iTunes. I have also tried Reiboot and it didn't work. On iTunes I keep getting Error 9 or the device can not be found. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I would remove all the screws from the board to see if something is causing a short or flexing it. Can you test the device with a different screen?
这个答案有帮助吗?
得分 1
1条评论:
I do not have a different screen to try but I will try to remove some screws
完成的
添加一条评论
添加你的答案
beeweezy18 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 127
