跳转到主内容
it says unfortunatley, system UI has stopped
I am using a LG pro max and the screen shows unfortunately, system UI has stopped
I am unable to use the device
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
i cant even get the phone to do a factory reset. the error message never goes away. i click ok when it pops up but within 5 second its back. i have an lg g4. i need help. i can't do anything on this phone, i can't even shut it off with the back power button. i have have to dismantle phone and remove battery.
完成的
hard reset your phone by pressing off button and volume key down
完成的
with the system unfortunatly ui has stop with an all black screen my phone wont do anything it barely let me power off but i have to keep clicking the ok button a lot of times and press the power button so i can get it to power off but thats all it does and when i turn it back on the screen is the same , i did the volume down and the power button and it still wont do anything at all who can tell e how to fix this problem .......?????? I AM VERY ANGRY WITH THIS LG NEED TO A BETTER JOB WITH MATTERS LIKE THIS .
完成的
添加一条评论
11个答案
最有帮助的答案
My other cell phones UI stopped working and it won't work when I hold the power button and the volume key down as it told me to do.
这个答案有帮助吗?
得分 3
1条评论:
My SONY
完成的
添加一条评论
Yes oppo a53 8g ram 128
这个答案有帮助吗?
得分 2
添加一条评论
If it is rooted and you do not know what you are doing, you might have deleted an odex file that patches that. Otherwise the systemui settings are corrupt and you might have to do a factory reset.
这个答案有帮助吗?
得分 1
4条评论:
I did a factory reset and nothing changed
完成的
I can not find a device called "LG Pro Max". are you sure that is the correct name?
完成的
me either i did factory reset and nothing change
完成的
完成的
添加一条评论
my phone kept syaing that and it finally shut down and wont turn back on
这个答案有帮助吗?
得分 1
添加一条评论
I use a lg Phoenix 2 and when I start up the phone it says unfortunately, system ui has stopped. I can't do anything on the phone. How do I fix it.
这个答案有帮助吗?
得分 1
添加一条评论
Just recently came up on my LG life’s good phone I literally don’t know what to do because I need to to work because my dad contacts me a lot on the my LG phone whenever I’m out with my mates
这个答案有帮助吗?
得分 1
1条评论:
I can’t even power it off or to a recovery option on the LG phone I have
完成的
添加一条评论
System ui battery ? not working
这个答案有帮助吗?
得分 1
1条评论:
Yes u can help me
完成的
添加一条评论
I have had this problem too. The error message "Unfortunately, System UI has stopped" pops up around every five minutes, and I can only access the first 5% of my phone. The battery charges fine, but the phone itself doesn't allow me to use the device because of the error message.
这个答案有帮助吗?
得分 0
1条评论:
Abert, did you find the solution for that problem? I have exactly that problem now! Thank you
完成的
添加一条评论
When the measage pops up hold the power button for complete shut down then click ok then quickly power of the phone and wait for the phone to eathier cool down or just turn it back on and try it
这个答案有帮助吗?
得分 0
1条评论:
I tried that and when turned back on it did same thing
完成的
添加一条评论
I'm having the same issue with my LG Pride I purchased from TextNow. The phone has been doing a slow crash on me. I should've sent it in for replacement as 3 days after i received it i stopped it in dog water. Placed in rice for 12 hours and it worked fine, though edge of screen stayed a light blue. My memory on the phone was very limited and I hadn 't yet gotten an sd card so I kept getting warning messages about "some functions may not work”. Anyway hoping someone finds the answer because I can no longer use the phone and all my information and pictures which I didn't sync are now unattainable.
这个答案有帮助吗?
得分 0
添加一条评论
Download a launcher and that will fix the system ui stop hope ull send donation :( poor here
这个答案有帮助吗?
得分 0
3条评论:
Download a launcher then go to setings then home make your new launcher as permanent :(
完成的
What's a launcher?
完成的
I can't do anything that message comes up n tryed everything n nothing happens
完成的
添加一条评论
添加你的答案
imtiyaz khan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 22,668
