跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
need part name by gas door
i have a 300 diesel but i need to replace the plug that keeps the diesel in i dont know the name of it it is a rubber thing like a plug by the gas tank that keeps it from leaking out its in the gas door to the left of the fueling hole any help i need so i can order this and get rid of the ugly gas spot and make my car newer again
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Can you provide a picture of the part you are referring to.
完成的
添加一条评论
1个答案
已选择的解决方案
Hello, are you referring to the hole shown to the left of the gas fill opening in this picture? With the red box around it.
If so that is there on purpose. It is a drain hole. Mainly, it is to let water drain out since the gas door is not sealed. But the other purpose is to let any fuel spilled or leaking from the gas cap/fill opening to run out of the drain instead of pooling up and running down the side of the car. This hole should not be plugged up.
If there is fuel leaking on the ground, going through this hole and down the drain hose, then the hole is not the problem. The problem is the fuel getting to the hole!
One very likely cause is that you may have a leaky gas cap. Consider replacing the gas cap seal as shown here:
Mercedes W123 Fuel Cap and Oil Cap Seal Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
tracy smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 161
