跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
Starbucks Barista primer not working
My Starbucks Barista machine has no water coming out. There is plenty of water in tank. Steaming function of machine still seems to work, though not as strong. Tried to follow the priming instructions, but doesn't help...never get any 4 ounces of water to flow through the steam wand as instructions state. Just a trickle of water, then steam.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
If you haven't descaled the boiler within the last few months then you may have some calcium build-up that is constricting the water passages or pump; you're only getting a little steam out because what little water is making it into the boiler is being vaporized. Be careful leaving the machine on for too long in this state as an empty boiler can quickly lead to overheating and a ruptured heating element.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
添加你的答案
rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 3,015
